4440 will not move when hot
Ryantaylor17
New User
I have a 4440 that the transmission light comes on after about 5 mins of work and it will
Not move have changed oil filters on the side had it to the dealer they said the transmission pump was gone brought the tractor back home split it put a new pump in and now still the same thing the dampener looked good on the fly wheel and the splines on the shaft looked good I'm thinking I have a valve stuck somewhere now when u use the tractor for five mins the hyd oil is getting supper hot and its stops driving and no Hyds or steering it's a 8 speed power shift with hyd front wheel assist
Welcome to YT.
You need to check pressures in each gear. There is a differential disconnect lever on LH side under operators station to disconnect trans from diff for testing.
