wilson ind
Have a JD M with pin in steering box which is wore out, As I understand the MT has two pins which contact the sector gear. I plan on leaving this tractor too my five year old grandson. I most likely will nor be around when he used this tractor. I wish to leave the steering as good as possible. What I would like to do in put a two pin shaft from a standard MT in the M. This would require serious machining of lower potion of shaft which is no problem. I cannot seem to find parts book information to decide if the two pin JD MT top would work same as the one pin M. Anybody have any information on this idea??
