1010 trans to engine
I have a JD 1010 that I am installing a different engine. When connecting the trans and engine I found that the inside shaft in the transmission does not turn. The outside shaft turns as it should. What is going on? I believe both shafts should turn. The tractor is in neutral. Any help would be appreciated. Thanks!
