Loading tires
Mark Poss
I am looking to add weight to my JD G for plowing. Don't want to use calcium chloride, thinking of using window washer -20 fluid. Has anyone done this? What type of pump is needed, and how to go about this? Thanks, Mark.
I loaded the 16.9's on my 60 pulling tractor w/ WW fluid. I only added about 350 lbs to avoid having to throw so many weights to get to 7500lbs. I used a submersible pump from Northern Tool in a five gallon bucket, just kept pouring in the fluid as the level in the bucket dropped. I also used an adapter from Tractor supply that threaded on the valve stem and incorporates a bleeder. If you put a shutoff valve in front of it, you can bleed off the air pressure occasionally as you add the fluid. I couldn't find WW fluid in bulk, had to by gallons.
