Electronic ignition on 720 LP ?
(1) Can an electronic ignition be installed on my 720LP?
(2) Can I get rid of the porcelain resistor behind the dash?
(3) Do I still need the coil?
Tractor is positive ground with the original generator.
I've put several units on...they wire up direct 12v from switch. Don't mismatch the coil get the one with kit and be sure to specify you ground. Dramatic improvements.
