35 hours ago i installed a new perma clutch and installed a new rear main seal while i had it all apart. I used a seal installer and installed the new seal and wear sleeve. I didn't replace the oil pan gasket since it wasn't ripped. I added a bead of silicone to the bottom of the rear main seal housing. Today The engine oil was low and the trans was overfull. I pulled the pan to check the gasket first and i had oil between the gasket and the oil pan. Is it possible i didnt get the proper crush on the pan gasket to seal housing when i installed? I wouldn't think the rear crank seal could leak that much but it could be possible? Thank you
