When you set the V mark on the flywheel for No. 1 cylinder to match the V mark on the housing, and you move the distributor to the far left, should the points be closed?
No matter how I set the points to .020 where I think the high spot on the lobe is, when I try time it and I match the marks on the flywheel to the housing, and I move the distributor box all the way to the left, it always seems that the points are open. What am I doing wrong?
