fuel level gas caps 50 60 70
mdross
Does anyone still offer the fuel level gas caps? They were equipped with a float and metal rod that poked up through the center of the cap as the fuel level dropped the rod would sink down through the cap.
Mike R
Well I guess if nothing else one could drill a hole in the cap and stick a rod through it and put a cork on the bottom of the rod ?
Hopefully if enough interest is generated someone will start reproducing them again I would take two at least.
After calling around again it turns out the Insurance industry had a big hand in eliminating these caps go figure.
(quoted from post at 07:06:13 10/12/16) Does anyone still offer the fuel level gas caps? They were equipped with a float and metal rod that poked up through the center of the cap as the fuel level dropped the rod would sink down through the cap.
Mike R
Can you use a modified cap with level needle from a lawn mover (cub cadet, Deere)??
