I recently purchased a gas fueled 1973 or 4 2030 and haven't been able to convince it to run for more than 2-3 minutes at one time since I brought it home. It will
start right up and then shuts down after a couple minutes. wait a bit and the same thing again. No sputters just shuts off. I thought maybe it was the circuit
breaker opening so I wired around it and it made no difference. Suggestions ? Experiences ? Any help or suggestions will be appreciated.
I should have stated that I've installed a new fuel pump, filter, condenser, coil, and gaped the points. I firmly believe it's an electrical problem because I've
probably had it started 30+ times and it just shuts off. Not a sputter. Just like to ignition was turned off after running fine up to that point. I also thought
wiring around the circuit breaker would indicate the problem if it was a short somewhere.
