John Deere D generator
rgjsat
I recently purchased a 1945 Model D in its working clothes. The previous owner used a 12 volt battery to start the tractor because the generator (and three 7" lights) was disconnected with no belt. He did point out that when the 12v battery was hooked up, the light on the dashed worked so it must have been hooked up to the battery somehow. The generator looked original (faded green paint that matched the tractor) and did not appear in bad shape from the outside. Anyway, I pulled the generator off to have it serviced and a repair shop said that it was a 12 volt generator which surprised me. My question is, did these tractors come with a 12 volt system? If so, were they positive ground as well? Obviously the starter worked with a 12 volt batter but is there something else I should be concerned with the starter?
One of the D's we had was 12v that I am sure was factory installed. I have used 6v starters with 12v batterys for years. They spin over good. Look up D parts and I am sure you will find a 12v generator listed. Most old cars and tractors were pos ground.
