750 No Till Drill
I've been using this drill today and have a couple of questions. I don't have constant flow to my drill for down pressure but have been maintaining around 8-900 pounds down pressure. How am I supposed to put scv on constant flow and pick up drill when turning around? Seed chart was low on uncleaned oats and I plan to check acre counter in the a.m., but seemed to be running high. Can't I run my scv as such?
Simple, You just lock the SCV into the down position WHEN your drilling. You lift it with the same SCV just pulled back. There is no need or way to lift it with the SCV locked to apply down pressure. There is a clip you snap into the console that goes in where the float lock out pivots. IF you look close at the slot in the console there is a square notch in the bottom side of the slot the lever moves in. This clip snaps into that square and the float lock flips down to hold it in that square slot. This clip is also used on the Pull type forage harvesters to lock the lever so the electric functions work.
The clip (#1) is part number R52667
