What can I use on my 37 b
Jdr315
I have a 37 b. What can I hook to it and use. Don't have any specific things I want to use it for but just curious what I can do with it. I have seen corn pickers , plows, and sickle bar mowers. I have searched for that kind of stuff but don't know what I am looking at I guess. It has power lift on the the back but no hydraulic connections. Thank you for any info.
To put hydraulics on that tractor you need a Baker valve. It is a section about 1" thick that goes into your power lift.
If you are planning to use it , get a 6 or 7 foot drag type disc harrow or
find an 2 bottom moldboard plow. Drag harrows, 10 or 12 foot seed drill.
They were used on wagons, hay racks, hay rakes ,drags, pulling logs. Any thing that horses pulled were converted to pull with tractors.
I remember Dad seeding with a 10 foot van brunt drill on our early styled B. I think it is a 1941 but would have to check the serial no.
That had a crows-nest Farmhand loader on it for years.
A '37B will be HARD Pressed to pull even a 2x12" Plow...
A single bottom 14"..I doubt a single 16" would be better..
11.84 HP at the drawbar..
1'728# pull Max when New..
1st gear is 2.25mph,,same as a GP, but a GP has 17.24 HP at the Drawbar and 2'489# pull and that is Marginal for pulling a 2x14"..
Hopes this helps you get what it will pull..!
