6330 goes to neutral
Tim [GA]
Got a call about a JD6330 goes about 15 feet and goes to neutral. My questions is this controlled by a computer, and if so can you flash the codes using a designated fuse? If not computer controlled is this electric over hydraulic? What should I be looking for as to the problem. Any information is appreciated for this old man.
Have not worked on xx30 series but the symptoms you describe are similar to what happens when a wheel speed sensor fails. From memory these sensors pick up the motion of the ring gear in the differential housing. I know this doesn't narrow it down much but thats all Ive got.
