Hydrualic Oil Clean Up Kit
Part number AR86239
Can anyone explain to me how this kit works? Yes, I know it is suppose to clean the oil up after major work has been down, but there are no filters in it
I know it is obsolete, is there a repalcment?
It has numerous covers and no filters???????
Deere sells a cleanup filter. They go in place of the regular hyd and powershift filters. Depending on how much trash was in the tractor, they may have to be changed out several times. I usually run the first set 10 hours, or sooner if they clog,have the remotes looped, and try to cycle all the functions to move the trash out with the oil flow. After you feel the system is clean, go back with the regular filters, but check them after 25 hours or so making sure there isn't alot of silver paste looking debris. If so run another set of cleanup filters
