My LA has been hard to steer for sometime, the problem is in the steering box. I finally got the worm gear out tonight and what I found was a Timkin roller bearing on the bottom which is in good shape and a ball bearing on the top which is destroyed.
Question 1: At the top of the worm gear is a metal ring in which the ball bearings ride on. Is this ring part of the worm gear or is it part of the old bearing and can be removed? It looks like it is part of the worm gear. Either way it is all pitted up so I would not want to install a new bearing with it like that.
Question 2: Should there be a race on the top side? When I removed it there was just the bearing, another piece of metal that looks like a cap for the bearing and then the actual gear box cover. What keeps the top bearing from moving around?
Question 3: The bottom of the worm gear has a small knub that simply mates up with the bottom bearing. Should this knub be the same diamter as the inner hole of the bearing? Should the bearing actually attach to this knub at the bottom? Or does it just rest on top of it?
Thanks
Thanks
