Is there a particular formulation of anti-freeze that I should use in my un-styled "D" - s/n 143458?
Is there a particular formulation of anti-freeze that I should NOT use in my un-styled "D" - s/n 143458?
I did not seal the studs correctly when I rebuilt the engine so coolant can get into the stud passages in the head.
If I only use water and some stays trapped in these passages, the head could crack in the winter.
Your advice will be appreciated !
JGC
JGC
