JD 4440 Starter Relay
8e3k0
Is the starter relay on a late JD 4440 on the front of the rear engine firewall or on the behind the firewall under the dash in the cab? Have the tech manual but it does not give exact location.
Any help would be appreciated. Thanks Ellis
Starter relay is in front of firewall on LH side above starter. Be sure relay is getting a good ground connection.
