John Deere 5500 Cab A/C wont work
widetrackman
New User
Was working fine after charging correctly low side about 32 psi. and was not overcharged. A couple of days later no power at clutch or high and low pressure switches. The wiring diagram shows a fuse 16 right after right after the t'stat in the wire that runs to the switches and comp. clutch. I can't figure out where the fuse is located. Does anyone know? Sure hope you can get to it without pulling the roof.
