4450 MFWD clutch bearing failure
Dan Hathaway
New User
I had a bearing failure on clutch shaft of MFWD . When bearing failed it allowed end of clutch shaft to egg shape hole in tractor clutch housing where lube oil is supplied . I have worked my way through Deere tech bulletins but they acknowledge this type of failure can happen but only suggest replacing tractor clutch housing . Anybody out there have any other thoughts on a repair ? Thank you
