My LA is VERY hard to steer, and has been like this since I bought it a few years ago. I disconnected the drag link and the front end is loose. As soon as there is any kind of weight on the front tires you cannot turn the wheel unless moving and even then it is hard. I decided to take a look into the gear box and the first thing I found was that the top bearing was destroyed. How do I go about removing the steering column/worm gear? I tried to simply unscrew it but it will not come out. Is there something else holding it in place?
Thanks
Thanks
