Hotflashjr
- Location
- Western MA
I had my LA running great this spring. I parked it inside back in May and have not run it since. I went to start it to do a little fall tillage and it wouldn't start. It is popping through the air intake when I try and start it. It seems like it wants to start but will not. I had this issue getting it timed a year ago when trying to get it back up and running after a rebuild. I have yet to have time to check the timing but find it odd that after sitting a few months the timing is in correct. It started easy and ran like a top this past spring over April and May when I plowed and harrowed with it pretty much every weekend so I have no reason to believe the timing was off. My guess is I need to move 1 cog on the timing gear on the magneto but anyone else have this issue before? Could it be a crappy condenser?
