jtgaff
New User
JD 300 Tractor with loader, T4W1D, serial #091770T, with a 7320 loader. The loader control valve has been dripping for some time, now is it leaking a steady stream. Are these re-buildable, or a replacement item. Where do I source another one, one with a "float" function. I believe I have a eight piston pump with a 23.5 gpm output.
Welcome to YT
Only leak that's repairable on spool on valve is o-ring(key 7) on each outer end of spool.
4 ea-T30942 O-RING, PACKING 4.79 USD 19.16
I have loader 7320 it has a different control valve. I found a picture of it on the JD parts, I do not know how to attach it to this post. the leaks are where # 10, and #33 on the diagram.
