1961 John Deere 2010
Edgehill
I have been cleaning this tractor up all winter,and today I decided to put new battery in and turn the motor over,since have not started since last
November. Check all electric connections and have power to all including the scileniod. But not get anything at all for engine turn over. If
someone could recommend a suggestion I would aprieciate. Thankyou.
If all else seems to be in order, I'd check the neutral start switch, which is inside the steering pedestal, and operated by a plastic lever/tab that's attached to part of the gearshift mechanism.
If your 2010 has the shifter lever on the right side of the dash - you might shove it fully left then fully to the right a couple of times to make a solid connection on that switch. It is only going to start when in neutral position.
Bob I decided to have starter,solenoid look at by a mechanic and found that everything was fine, he assumes I had the wire on solenoid on the wrong terminal..
