We have a JD 6300 and for the last year or so the 3 point would bounce some when using it. when you set it to a height it
would go up a little then back down.. Not enough to bother us really. I just got off of it today from mowing hay and I noticed
that if when I let the arms down they would stop at the right height then slowly leak down. It will also do this when you
raise it to a point and stop them it will slowly raise up . it goes to either all the way up or all the way down.
Is there a reasonably easy way to fix this or does it need to go to a mechanic?
