On my late model A, I attached my hydraulic cylinder for the first time in many years and I can't get the bottom coupling to stop leaking. I looked in the parts book and it calls for two small O-rings and one big one. When I looked at my coupling I see only one small o-ring on the narrow part of the coupling and the large o-ring on the thicker part of the coupling. My question is, if I put two small O-rings on, where does the second one go? I can see where the first one fits, but if I put second one in , it looks like it will just ride up against the first one. Is this correct?
Also can you use the O-rings that you find in home depot, or are these special O-rings?
