830 pony start ignition switch
wttnlarry
I wonder if any of the JD 830 diesel experts could draw me a diagram or give me clear directions as to the wires that should be connected to the two post on the ignition switch that the coil type resistor is connected to. I do have the parts book diagram but it just isn't very clear. Thank you for the help that you can provide.
Ar you referring to the headlight dimming resistor?
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/Deere/DEERE_2_cyl_Diesel_wiring_zpsskcdhstf.jpg">
Hello Bob and thanks for your reply. Isn't the diagram that you are showing me for an electric start version of a JD 830 2cylinder diesels which was made in the late 1950s til 1960. My tractor is from the same era but has a pony motor start, also called a cranking engine
Not sure if this helps due to such small print
http://img.photobucket.com/albums/v437/M-MAN/SM-2029/830--D-JPEG.jpg
John T
