Mac AR
- Location
- The Hills of Home - The Ozarks
Today, I drained all the 90 wt, out of my 1950 B. And it needed it. Was a Carmel color. So, I went to refill it, and I thought the small pipe plug next to the oil filler was the hyd fill. Fyi, it ain't. I ran the tractor for 30 minutes, and noticed it smoked some. (Go figure!) so I checked the oil. Amazingly, you can put 4 gallons of 90 wt. in the crankcase and run it.
So, the question is, how bad have I screwed up? I've drained the crankcase, and am going to let it drain all night. I plan to fill with 30 wt, and run it a few minutes, then drain and change filter, refill and run a nit, then change oil and filter again. Good plan? Should I do anything else? I appreciate anyone's help here, this is possibly the dumbest thing I've ever done regarding a tractor.
Thanks, Mac
Thanks, Mac
