Well talked to one of the guys who talked to the machine shop. Said the block is good no crack and not warped. Going to have the cam bearings installed by them and then it should be on it way back. Going to drop off the head and crank tomorrow so they can be checked out. I was a bit worried about the block because I found 2 sleeves that had been silicone in so figured it was best to have the block checked out before sending in the crank and head.
I also got the clutch throw out bear shaft freed up. Now ht pedal will drop if you let go of it with out the springs in place. Before I started just to push it down was a chore and a half and that was with the clutch out and no spring hooked up
