So this 1020 I am work on ha the clutch throw out bear shaft hat is so stiff that it is next to impossible to push down. So I'm thinking it would be best to pull it out to clean things up so it moves freely like it should.
So how is the throw out bearing finger held onto the shaft. To me it looks like a couple roll pins but want to know for sure before I try to take it loose. Once it is loose I'll clean the shaft up and then pull it out so I can then in turn clean out the pivot holes it sits in. This bell-housing has a 1/4 inch of rust all over it
Thanks
Thanks
