RandyB(MI)
Not a governor man...that being said, '37 JD "A" has lot of oil pooled in behind mag. Ran wire down in drain back hole. Goes about 3" and hits solid. How can it drain back ? Hits right about where base of gov meets block. Any chance someone put a new gasket under gov and it didn't have a drain back hole in gasket? The wire hits solid...not like a sludge blockage. Maybe it turns back horozontally down there ? Not my tractor but owner wanted me to "see what can be done" about the excessive oil that leaks out through mag. Probably 1/2 pint came out when took mag off. Help appreciated. RB
