I am simply wanting to know for sure which drain plugs are for which, on the underside of my John Deere 730 2 cylinder tractor. I assume the drain plug right next to the Oil filter cap is the Oil crank case drain plug, correct? The second drain plug on the underside, is essentially right above the front end of the drawbar. Is that the Transmission Drain Plug? Then, back a bit further, but more towards the flywheel side of the tractor is another drain plug. Is that the "Rear axle Housing Drain Plug"? Last question: Is the "First Reduction Gear Cover Drain "plug" a plate that has 3 bolts in it on the under side, just under the belt pulley/clutch assembly, just like on the upper side of the pulley, or should I be looking for a plug, just like any other drain plug?
Thanks, in advance! - reb
