smokinjoe3
Finished bushhogging yesterday. Everything worked fine. Unhooked the bushhog and pulled away. Went to back the tractor in and I saw the 3 point arms creep up. The control lever was in the down position, but 3 point arms were at the top. Turned the tractor off and the arms went down. I let the tractor cool for several hours and got back on it. With the control all the way forward I started the tractor and sure enough the 3 point arms started to creep up. The control seemed to work and when I pulled back on the lever, the arms raised faster, but even with the control all the way forward, the arms will not lower. I tried searching the forum for this, but seems like most people have the opposite problem of the arms not raising. Can anyone give some advise on what to look for?
On a side note, I just replaced the 1/2" pressure line coming from under the dash to just to the right of the hydraulic filler neck on the rockshaft cover prior to bushhogging because of a leak. Steering, brakes and 3 point all worked great after replacement. Currently there are no issues with steering and braking.. Just the 3 point issue.
