48 A hydraulics
a49deere
Reposting this question in hopes of getting some response. 1948 A with powertrol. Hooked up a test gauge to output to cylinder. Started out at about 700 lbs then as I opened and closed valve on test gauge a few times pressure gradually dropped to around 400 lbs and maintain that. Looking for suggestions on possible cause. Weak relief spring? dirty relief valve? worn out pump? Please help, thanks Greg
I would check the relief valve first. Then the check valve. If those are ok,check to see if the directional valve is returning to center.
