My 1951 JD B has the wheels set out to the end of the axle shaft. I got the collar's off that squeeze the fingers on the hub that lock it onto the splined axle but I cannot break the hub away from the axle splines to move the wheels in. Is there a method to do this? I pounded the hub with an 8 lb sledge hammer pretty hard but could not move it.
I wondered if I could break the hubs loose by driving it around with the retaining collar and bolts off?
Anybody have solved this problem on this board?
