JD 4555 Powershift
fordfx413
I am air testing my work before I go all the way back together. I blew some air in the b2 circuit on the shift valve and air is coming out the hole above the valve sump? I have no other lines hooked up. I installed new gaskets in the shift valve and new packings between the valve and the cast. I tested with air before I installed the shift valve and it engaged. I added a photo of the hole. TIA
Picture of the hole
