JD 4555 Lube Pressure
fordfx413
I have my 4555 opened up doing some transmission work. B2 clutch failed. When i was first testing the tractor I had zero lube pressure at 1000 RPM. At 1650 RPM i had 10 psi. Should i have had 10 PSI at 1000 RPM? I asking now before i get the tractor buttoned up... TIA
