model 2355 hydralics
R Geiger
A friend is working on a 2355 that is having an hydraulic problem.
Every thing moves but does it real slow. He check and or replace all of the filters with no chance. Is there a place to test the pressure. I found thaat the operating pressure is 2250 lbs.
Did he check and clean the sump screen???? You have to drain all the hydraulic oil out and then take the sump screen out. On a Mannheim designed tractor I always start with this.
