Well I did finally find the engine tag hiding behind the loader frame serial number 045020T so that is an early single o-ring type seal.
Now for the crazy thing I found on #1 sleeve. When I pulled it out it appears that some one had used silicone gasket maker in place of the o-ring that should have been there and the other 2 sleeves appear to be cracked.
Next thing I get to do is split it so I can pull the crank shaft out and send it to the machine shop to be checked and turned if needed. Does not look like it will be fun to split it either
