Faster road gears for JD tractors from Ohio
matthies
Can anybody give me the contact info for this company in Ohio. Have a set in my 50 just wondering what other models they can help. thx
You could try what the old timers used to tell me.."Tie baling twine on the governor link to the carb and use that to override the governor".. I have no idea if it works but...??
id hate to speed a B and bigger 2 cylinder up.long heavy rods flyin too fast might want to live in another part of your crankcase 630 is what 1250 rpm load rated and a b is 1175 rpm isn't it? experience also when an engine has broke in at say 11oo rpm governed and year later you bump rpms up much trouble begins sneaking up on you.neighbor sped his g 900 minni mo up 600 rpm.had it on a generator at his milk barn. called me about 4 am said tractor quit. yes it did a rod was stuck in an oak tree a good 10 feet from where he had ol mine makin juice in middle of summer. we had a power outage .I had my 1370 on my generator n other neighbor had his 4440 on his .we cooled our milk down and took turns going to bills house keeping our milk cool till truck got there .that nite he was kinda late milking cause we did ours first then his but we helped each other out
Yup, Mike. Our H had that pedal also! The pedal got it thru hard spots!! Good little tractor. Had the hydraulic pump located on left side of the front pf platform, with a flip up and down lever. One bottom two-way hydraulic lift plows. Ran a #5 7ft hydraulic lift mower GREAT! Great hay raking tractor and small manure spreader puller.
