1963 1010 RUS hydraulics
wkellen
New User
I have looked through 2 different spec sites on this tractor and can't find what hydraulic pump is on it or what the GMP rating is on it. I would think it is low since the fluid capacity is 4.5 quarts. Anyone know for sure?
Thanks,
Wayne
The Specs have the Hydraulic Fluid Capacity, it lists 4.5 gal and 4 1/4 quarts. So which is correct? I need to change the fluid and I don't know how much to buy.
The transmission holds about 4.5 gal and the hydraulic system for the lift arms in the back hold about 4 1/4 quarts,
There are 4 fluid systems on the 1010
Transmission and diff (Both share the same fluid)
Left side final drive
Right side final drive
Hydraulic pump / Lift arms (Both share the same fluid)
The lift arm and hydraulic pump system is the one I am talking about. I want the pump specs though.
PM me your email address and I'll email you the factory service manual for the 1010 - the info you are looking for should be in there.
Great info! Thank you so much. It gave me the GPM rating of the power steering part of the hydraulic pump (if equipped, mine isnt). Nowhere did it give info on GPM flow of the hydraulic pump only. I did find more useful info in the manual. My PTO shaft just quit and it shows all the parts involved. Mine seems to be missing a roll pin and a snap ring has worked its way toward the internal end of the shaft. The shaft no longer has a groove for the snap ring.
