3150 hyd pump
Our 3150 hydraulic pump is leaking. Looks like the oil is comming out between the front cover and pump body. Is this a leaking seal? Should I pull the pump or can it be repaired in the tractor? Thanks!
If it's like other JDS of the Era, pull the pump out. Not to big of a job, remove hood, fuel tank and drive coupler. Much easier to inspect and change the pump shaft if needed. Ben
I suggest to check the 4 capscrews(key 13) to be sure they are tight. If leak persists I think pump will need R&R & seal kit installed.
