So I found another get you part on this 1020. The clutch shaft I guess you would call it had pulled out a bit when I took it apart. Tried to put it back together but lacked about an inch of getting it. Tried a couple times then pull it apart all the way again and pulled the clutch shaft all the way out and found a place on the shaft and the bearing area that had to be lined up just right or things would not go back like they should. Oh well something else to go into the learned something new file. But at least it is not on 4 wheel again at least till I split it for the clutch job but going to find the engine oil/coolant problem first. I also have a feeling that the starter may have a problem since I could not get it to spin the engine over. I even tried to go from the small wire on the solenoid to the battery cable and it would just click and not spin it over.
