JD 1010W distinctions
JD1010W
New User
I recently purchased a JD 1010W tractor with loader. I have an original owners manual that covers models O, U, R, RS, RU, and RUS, but no mention of the W. Can anyone tell me what the distinctions are for the model W?
Thanks for your help!
I know that the model exists, just trying to figure out if there are any differences in engine, frame, gears. etc. to give the W designation.
the W stands for wheel tractor. or Industrial because they were mostly all painted industrial yellow.
this tractor was based on the RU version with the same transmission and final drives.
only difference is the W tractor usually did not have extended long rear axles.
instead they were fitted with a plain hub that the rim bolted to and was not adjustable.
Most of these tractors had power steering, heavy duty rear fenders and a float ride seat.
The front axles were heavy duty and not able to be adjustable, and most had a remote mount hour meter.
saying all this there was alot of options that could be ordered through dealers AT an extra cost.
another term for these tractors was the Landsape tractor because alot of landscapers liked them for their
convenience and that they had a backhoe on the back and a few slab counter weights mounted on the front just ahead of
the grill.
they can be a nice tractor but mostly industrials of any model or brand were drove hard by several different
operators and put away wet.
hope you got a good one and enjoy.
Jd addict
thank you very much! I as well ust bought a 1010w with the gas motor and a loader/backhoe. I am new to JD, and its got some issues with the power steering and electrical. I bought the service manual but it barely covers the power steering and no mention of the w at all so I thought I may have ended up with the wrong manual!
Any and all advice as to info on this thing would be great!!
Thanks in advance!!!
