4020 hydraulic line identification....
Howdy folks. First, thanks for the help with the 3010 that had been sitting for 5 years...now on to the 4020 that's been sitting for at least as long. Reason it got parked is a steel hydraulic line split, and got taken off to be repaired. Dad was a whiz at being able to weld these steel lines with his stick welder! (I am not as good, I just seem to make the hole bigger.)
The line I'm talking about is a pressure line under the dash both beginning and end. Goes from up right towards the front of the powershift in 8th gear, down to the center of the steering box where it is accessed by taking the plate the keyswitch mounts in, off. Pics included. Looks to be 1/4" flare on both ends and probably if straightened out about 18" long. Since I don't have it any more, I have no idea what it looks like other than that.
Any help with what it might be called in the parts catalog on line or even a part number if someone's had this guy bust loose on 'em, I appreciate it. Only one I've found is AR44043 but not sure if that's it since it's not clear what it is in the parts picture.
Thanks!
Top pic is of where the upper end of the hose goes.... bottom pic is looking through the access door, camera is about where the headlight switch would be with the door bolted shut.
(quoted from post at 17:55:05 08/16/16) Make a hydraulic hose ...if u can't get
a steel line
I've done that plenty of times, Chuck! That thing's got more rubber hydraulic lines on it than steel, seems like! If the spaces wasn't so tight under the dashboard, I wouldn't have even bothered looking for the OE line.
