Help identifying an old JD part number?
I need help to see if this excavator bucket will fit my 690B( AT188055) The fellas at the Deere part store can't find it anymore. No one has responded to my request on the crawler site. Any help would be appreciated, Thanks Rick
Did you try an agricultural dealer or an industrial dealer? An ag dealer would not have access to industrial part numbers unless the part is also used on agricultural machinery. It may be different now but it used to be this way when I was a parts manager years ago. Mike
That number was not listed in the 690,690b or 690c listings,, but that don't mean it may not fit,,you will need to get some actual measurements for comparison..
Thanks for the help, I finally got a hold of the guy with the bucket. The dipper arm can only be 9" wide, and mine is 13.25. I guess I'm out of luck. Thanks for all the advice, I always can count on you guys...
If it is the size you need and it is cheap buy it. It won't take a good welder too long to make some new mounting brackets or move the ones on it.
