Seal cooling system
JDJACK
What is a good product to install in the cooling system (water) of a John Deere 2 cylinder without a water pump, to seal a water leak in that is getting in the oil.
In the long run it is better to find and fix that type of problem. But that said if I where going to use any type of sealer I would use the bars leak copper. I have used that in more then one machine and it has worked just fine
I sealed the radiator on my 44 B with Mendtite. Get it hot & under load & keep working it for a couple hours. Don't put the sealer in until the temp is up to normal.
