Looking for some advice.
I own a 1963 John Deere 3010 Gas. I have recently installed new distributor cap, rotor, wires, plugs and and pertronics electronic ignition module for 12 volt + ground. Since the installation I am able to start the tractor only with the key switch in the start position. Once I relase the ignition switch (back to run) the tractor will stop running. I have checked my coil for 3 ohms and that is correct. My coil has a built in resistor. My wiring is as follows as the instal instruction per the electric module. The hot wire from the ignition switch goes to the correct marked wire of the module. The correct wire that comes back from the module goes to the negative side of my coil. the positive side of my coil wire gets grounded to the engine. The wiring is correct as per instructions by Pertronics. I have checked my voltage at the negative side of the coil at it seems to be on the low side around 7 volts, I am unsure of this. My battery is around 12+ volts. I have not checked the wire that comes from my igntion switch to see what kind of voltage I have prior to the module yet. I would assume that I should have the same voltage as close to my battery. I am unsure of my ignition switch at this point. As up to the instal of the new module and tune up, I have not had problems starting the tractor most of the times. She could sometime be miserable to start on a cold start sometimes, although my next angle of maintenance will be the carburetor, but one step at a time.
I am grateful for any help in this matter.
And Greetings and look forward to any helpful advise I could possibly offer to this group.
Respectfully.
Jerry Long
Respectfully.
Jerry Long
