Chesterton angelo
Been trying to get it running right. Took
out the carb, cleaned it soaked and used 6
in drill bits #40 and # 53 to clean out the
passages. At idle, the idle screw is
working and I can adjust it. It is just
running incredibly rough. It is puffing a
lot of smoke out the exhaust and burning gas
like crazy. Also when I turn off the gas and
let the motor run dry, right before it dies
there is a 15-20 second time where it starts
idling perfect and stops puffing smoke and
then the motor dies. Anyone have any ideas
what is going on? Could the float level be
causing this? It is not adjusted right and
letting to much gas in? Causing it to run
really rich?
really rich?
