Hinsen Cab off 4020?
larryanderson
Taking Hinsen cab off 4020JD .Question will any platform fit off NewGen tractor? I know dimmer switch and hyd oil fill need to be addressed.If anyone needs any parts such as mat windows door make offer and I will send them to you.Thought I could sell it cheap but no takers.Just too noisy compared to newer ones.When we farmed with them I thought I had it made as they were warm in winter cool in summer and at the time tolerable with ear protectors.
Only one platform is listed in 4020 parts catalog for SN >201,000 rowcrop tractor and it's part number AR48727 same as 4010,early model 4020 & other models. Dimmer switch application for platform isn't addressed in PC that I can locate.
AR48727 is listed as the current # but it is a sub for older part #s on 4010 and early 4020 models. Looking at the footnotes on early 4020 parts page, I suspect it has the holes for the dimmer switch and also the slot for the power shift tow disconnect lever. In reply to OP's question, any platform will bolt on but there are minor differences in them. Exception would be early powershift which is raised in the center, probably still bolt on a synchro but wouldn't look right.
We took the Hinson cab off our 4320 a while back and tried to put a non side console platform on it and we had to do some grinding under the seat pedestal if I remember. In the end it did work to answer your question.
Paul,sold door and back window.If you send me your address I will send side window to you for whatever freight would be .Speedy is cheap or Priority mail usually is better than FedEx or UPS.Priority Mail at $18 anywhere U.S. is good but 70# maximum and has to fit in their special box.It is exactly the size of a 9 bolt dual hub with no wedges and bolts 68.5#.They B&M some but they seem to get there.
