machineryman
I am taking M-Man advise and adding an electric pump part # is Am876266 and it's used everywhere...low pressure and there's a place with two taps on the manifold suppose they may of had this in mind. Still I never could understand if the tank was just too low and when you got on slop you lost gravity feed then the pump picket up air out of the vent return or if in actuality the noze was exposed and got air that way. I guess I'll try the pump and find out. JD price $130...ebay price $15.00. I decided not to mess with tank as this is buggering up an expensive item and I'd have to weld on it...
